There are upgrades you make to a motorcycle because they look good. There are upgrades you make because they promise performance, and then there are upgrades like the Akrapovic Titanium Footpegs—ones you install, ride with, and realize you should have installed a long time ago.
I recently installed the Akrapovic Titanium Footpegs on my 2021 R 1250 GSA and put them through everything from long highway stretches to standing during heavy off-road riding. What I realized was that Akrapovic didn’t build these as a simple cosmetic upgrade. They improve control, comfort, and versatility.
Akrapovic built its reputation on precision engineering, primarily through its dominance in high-performance exhaust systems. That DNA is clearly evident here. The footpegs are cast from Grade 5 titanium, used for its exceptional strength-to-weight ratio and corrosion resistance. Pick them up and you immediately notice how light they are compared to OEM pegs, yet they also feel much stronger, thanks to a reinforced framework that maximizes rigidity while keeping weight down. It’s not just for looks, either—this design translates directly into a stable platform underfoot.
Mounted on my bike, the pegs’ wider footprint compared to the stock BMW pegs is immediately noticeable and immediately beneficial. Whether riding off-road or simply transitioning to a standing position on gravel or uneven pavement, that extra real estate makes a huge difference. Instead of balancing on a narrow strip, your boots have room to move, adjust, and distribute your weight more naturally, spreading your boot pressure across more of the sole. This inspires confidence on technical terrain, enabling me to easily shift my weight to make steering easier and more precise. On longer rides—particularly those that involve extended periods of standing—the benefit becomes even more pronounced. You’re not constantly repositioning your feet to stay comfortable. Instead, I can just settle in and ride.
For me, one of the best features of the Akrapovic Titanium Footpegs is the removable rubber insert. Each peg includes a rubber pad that can be installed or removed in seconds without tools. It’s a small feature, but it changes how the pegs perform depending on your riding style or conditions. Without the insert, the pegs offer maximum grip from their aggressive tooth pattern, making them ideal for off-road riding. With the inserts installed, the pegs provide added vibration damping for greater comfort during long road rides and easier foot repositioning.
I appreciate this versatility and see it as getting two sets of pegs in one product. Heading out for a long highway day? Pop the inserts in. Planning an off-road route? Pull them out and go.
Installation on my R 1250 GSA was straightforward and if you’ve ever swapped footpegs before, you already know what to do. It’s as simple as removing the existing footpeg retaining pin, swapping the stock pegs with the Akrapovic Titanium Footpegs, and then reinstalling the spring and retaining pin. Once installed, I found everything lined up correctly, and tolerances were spot-on.
I believe Akrapovic has taken something as simple as a footpeg and turned it into a highly refined performance component. On my R 1250 GSA, the wider platform alone is worth the upgrade for many riders, allowing longer, more comfortable standing rides. Add the removable rubber insert system, which lets you switch between maximum grip and cushy comfort, and you have a product that adapts to your riding style.
In the end, these footpegs deliver better control, greater comfort, and a noticeable improvement in how your motorcycle feels under you. The Akrapovic Adventure footpegs retail for just over $314 and are available at your favorite online retailer.
